#21
You can't use the 682 sheetmetal on a 149 frame. They are very different towards the front. You will need 582 clutch parts, which unfortunately happen to be harder to find and more expensive than all of the others. You will also need to add a pillow block bearing at about the midpoint of the driveshaft if you are extending the frame 24 inches.
#22
anybody got an old 582 laying around? LOL Mike
disabled/desert shield/storm vet, proud to have served! 582, 1782, 124 (x2), 154 LO-BOY, |
#23
Here is one, but it isn't close to you. There are also some clutch parts for a 582 on ebay.
http://cgi.ebay.com/Cub-Cadet-582-PA...item3a60617413 That is about all the help I can give you. My head is still spinning from reading about all the different frames. I thought as you, that there where just wide frames and narrow. Man, when I thought I was getting a handle on some of this you guys had to go and throw a wrench in it all.
Chip T. Drexel NC |
#24
#25
Mike,
Being that you intend to stretch the frame anyway, and you have the two frames side by side, is it possible that you can add the front frame rails from the 682 to the 149 frame?
#26
Personally before you spend the money on the overdrive gears, I would look at using the 154 clutch and main shaft. without the reducion housing on the trans the input is lower physically and you could set up a 2:1 chain reduction off the motor to run a drive haft back to the clutch/trans. without the front cadet reduction you are the same as a Fcub your motor is just going to be twice as fast so you reduce it to half as much before you get to the trans. It is easy to convert a cadet trans over to a 154 input, I may even have all the parts you will need (couple bearing retainers and a bearing cap)
#27
Mike
#28
Mike
