Greg Rozar AKA- CubDieselFan
Old 12-14-2020, 08:19 PM
MikeM MikeM is offline
i measured the spare belt i have MTD 954 3075 3 times and each time i came up with 77 7/16" aprox 77.44 if taking the outside measurment is correct that is over a inch smaller than the dimensions you gave me. that would make the differance.
Old 12-14-2020, 08:32 PM
Here is a Video on how to measure a V Belt....
https://www.youtube.com/watch?v=2kYLYrw0gUE
Roland Bedell
Buy: Made in the USA
Old 12-14-2020, 09:43 PM
Thanks for the video, i tried all the methods except the string and came up with 77 5/16 to 77 7/16 multiply times.
When my CC dealer and i measured the belt we had a couple of years ago i remember it matched the info he had but i don't know what that was and that belt was extreamly tight also.
Should i contact MTD and give them all the info i have and see what they come up with.
Old 12-15-2020, 07:05 AM
954-3075 PTO Belt 78.6" Long
Again, here is the spec on the belt.
"B Section V-Belts are measured on the inside diameter."
B75 - B-Section V-Belt (5L780) 5/8 X 78
B76 - B-Section V-Belt (5L790) 5/8 X 79
Roland Bedell
Old 12-15-2020, 07:55 AM
At this point you have 2 options.
#1:Continue using the short belts.
#2: Get a belt 1" longer.
and it will go on easier, and problem solved.
You will keep your shorter belt for an emergency spare.
Using too short of a belt causes excessive wear on all drive components,
including but not limited to, belts, pulleys, bearings, idlers,etc.
and causes you aggravation with removal/install.
Old 12-15-2020, 08:15 PM
i really don't know where to go from here except to get a longer belt, i am confused and really appriciate all the help and input.
No matter how i measure the belts i have (954-3075) they measure aprox. 77.4" both ID & OD which makes no sence to me i would think the OD should be larger than the ID. But the conclusion i have come to is the belt appears to be aprox. 1" smaller than it should be at 78.6".
With the information provided on this forum i am going to seek a resolve (belt length) from MTD.
Thank you so very much for your help
Old 12-15-2020, 08:55 PM
I highly doubt you will get anything from MTD, but I wish you luck.
Old 12-18-2020, 06:06 PM
ironman's Avatar
ironman ironman is online now
Consider this....if you take a razor knife and cut that belt perfectly across perpendicular to it's length, and stretch it out on its side on a flat surface perfectly straight, and measure the inside and then the outside, do you realy think the measurements would be different???
