Greg Rozar AKA- CubDieselFan
Old 07-14-2020, 05:41 PM
tobo127 tobo127 is offline
Default #2 Tiller refurbish
Just finished refurbishing a # 2 tiller (came with a 109) to mount on my 1450. Hardest part, as all who have one know, was getting the rusted/frozen tine tubes off the output shafts. Here's a few before and after pics. Just hate to get it dirty now!
Old 07-16-2020, 10:01 AM
garydee's Avatar
garydee garydee is offline
Default Tiller refurbish
WOW!! What a transformation! A pleasure to see!!
Having restored a few pieces of equipment myself, I can appreciate the work that went into your project. Keep up the great work in future restorations!
Old 07-16-2020, 10:08 AM
Very nice work.
Roland Bedell
Buy: Made in the USA
Old 07-16-2020, 01:52 PM
Looks good!
Did Ya repack the chain box and replace 'em too?
Old 07-19-2020, 10:34 AM
Did everything but take the gearbox apart on the Model 2 tiiller. The tines looked to have very little wear, there were no signs of leakage of grease at shaft bearings, very little play from input shaft to output shaft.................so I'm assuming (hopefully a correct assumption) that the internals are operational. I have a Model 1 tiller also that was in way worse condition that I tore completely apart. That one looked great internally (sprockets were fine, chains looked new) despite someone cutting a hole in the case to let whatever inside, and the tines were worn down to a point on the end. So I'm thinking these gearboxes are rugged enough to take a beating and survive. The manual says the gearbox requires no periodic maintenance..........we'll see! If I have to get inside the Model 2 later, at least the tines will slide off the output shaft easily!
Here's a before and after of my Model 1 internals:
Old 07-24-2020, 11:19 AM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
Mighty fine job!
1450SGT
1641
528 SWE Snowblower,
Old 07-25-2020, 11:19 AM
SGragg SGragg is offline
Very nice! That should give you good service for years to come.
Old 09-22-2020, 01:57 PM
jdougs jdougs is offline
Nice work. Can you tell me if the shaft/s the tines are mounted is suppose to have any movement to it besides rotation? I noticed mine move up and down when I was cleaning it and it struck me as odd.
Old 09-25-2020, 12:29 PM
Sounds odd to me also. The bearings should be mounted in their flanges quite tightly. Any movement could be loose mounting bolts (should be obvious), or maybe a worn shaft spinning inside the inner race (dust cup worn out, letting grit into the bearing, seizing the bearing)? In any case, I'd look into the problem and address it before any (or more) damage is done. If never removed before, good luck getting the tine tube off the output shaft. Both of the tillers I've done were a real bear to remove (lots of penetrating oil, soak time and heat, a big puller setup, a lot of banging, finally success)! Once removed, it's certainly worth the time to occasionally remove, clean and re-lube the tube shaft. Also a good time to recheck tightness of all hardware. These units take a beating when in use but do a great job!
Old 10-04-2020, 05:22 PM
Thanks for the input.
JD
Thread Tools
Display Modes
