Greg Rozar AKA- CubDieselFan
Old 01-18-2019, 05:58 AM
russlavoie23 russlavoie23 is offline
Default Repowering a 1650 Hydro
Hello ALL,
I just purchased a 1650 hydro, so I'm new to Cub Cadets and this forum. Just had a question on repowering my tractor. The other day my K301aqs let go and seized up, and I'm looking at doing a direct swap. I was able to find a motor for sale online and was wondering if this would be a bolt in application for my tractor. Thanks!
https://www.ebay.com/itm/JOHN-DEERE-...0-33217c9d8733
Old 01-18-2019, 07:14 AM
Welcome to OCC,,,
as far as the engine,,,
a 1650 tractor has a 16 HP engine,, or K341,,
the engine you have found is a 12 HP engine,, or a K301,,
Possibly the engine in your tractor is incorrect due to a previous engine swap?
That eBay engine is a little pricy, considering it is a small engine,,
maybe you would be happier with a K341,, or at least a K321,, 14 HP,,
there is no carb on the eBay engine,, we do not know what carb is on your engine in the 1650,,,
With the missing pieces,, you could be over $1,000 before you get the too small engine running,,,
Old 01-18-2019, 07:55 AM
First, welcome to OCC....
The listing you provided, is for a John Deere Tractor. When Kohler builds an engine for a tractor manufacturer (ie: Cub Cadet, John Deere, Wheel Horse. etc), they build them to the OEM's "specifications". Thus. a K-341 (16HP) have all the basic motor builds, there are numerous variations (crank, cooling, mounting, etc).
IT IS BEST, when replacing a Cub Cadet engine to make sure that it meets Cub Cadet "specs". Thus, you will have a trouble free drop in replacement.
Roland Bedell
Buy: Made in the USA
Old 01-18-2019, 08:32 AM
Thanks for the quick replys! It did have a 16hp in it originally however it was replaced with a k301aqs which is in it now. I was hoping if I couldn't find another motor I could just pull all the odds and ends off my k301aqs and transfer them right to the motor I had listed.
Is there a good site to purchase these motors? Just want to get my tractor up and running again.
Thanks again
Old 01-18-2019, 08:37 AM
Tried posting pictures of the tractor but no luck
Old 01-18-2019, 08:45 AM
twoton twoton is offline
So what's wrong with the current motor?
Old 01-18-2019, 09:43 AM
It seized on me, I got it free but now it cranks with no start and weak compression. I was turning it over the again trying to start it and it just seized again but ended up freeing it up again. I wouldn't be opposed to having this one rebuilt as it made great power and ran excellent when it was going. Motor seized all of a sudden no typical warnings.
Old 01-18-2019, 10:07 AM
Sounds like a problem with the compression release. I think you should investigate a bit more before you condemn the motor.
Old 01-18-2019, 11:01 AM
Gompers Gompers is offline
How mechanically inclined are you?
Rebuilds aren’t too tough on the K series, and parts are cheap and readily available.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 01-18-2019, 02:21 PM
I'm not too mechanically inclined but I've been exploring the full rebuild kits. The machines only doing light work so if I didn't get the 14 or 16 back on the machine it wouldn't be the end of the world. Anyone have any luck with the isavetractors provider for a rebuild kit? Listed at about $240
