KT17S with 3 serial numbers...which is correct?
My 682 has three serial numbers in a group on the motor shroud. Is there another place with numbers?
I only see 2 serial numbers, but 3 tags.
Likely, it was replaced at some point. The big tag on the side is the newer tag. New engines didn't always come with tins, but would have came with a serial tag. |
This is what you have:
M/N: KT-17S Series II Spec No: 24302 S/N: 14005601 Which rolled out of the Factory, in 1984.
I figured you all would know, thanks.
We gave conflicting info though..... so which tag are you going off of?
I'm going with the big tag on the side
From the Kohler KT Series Service Manual.....
Yes..... that's correct. But if the engine has been replaced (highly likely) the new engine would have came with a new serial number and a new tag, which appears to have been placed on the tin just below the original serial number. So, the lower big tag would be the new SN.
Looks like the newest serial number you have there is from 1988 (18xxxxxxx). So it's likely that your engine was replaced with one about 4 years newer at some point.
It kinda stinks that the only place a serial number for these engines exists is on the tins. They get swapped around after rebuilds and replacements and you can never quite trust them.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
I agree. Serial number isn't really all that important anyway. Seldom do you need it. Spec number isn't a big deal either if you know the application, but it's more important than the SN because it gives the build. |
