#71
BTW, those springs were tricky just like everyone said! |
#72
Is this the kit I need for my 1782 Cub? Looks like I have a leak from on top of my steering box..
https://www.messicks.com/part/21-sk000011/sealkit |
#73
https://www.messicks.com/part/21-401443x1/spring-a |
#74
Dredging up an old thread here. I've got an 1872 with hydro fluid leaking out of the TOP fo the steering column at the wheel. I assume, in reading thru this thread, and others, that my bits need to be rebuilt with new seals etc. My big Q is, how am I to be sure what model steering valve is on this unit? While I don't need to use the tractor over the winter months here, it's going to be a large hassle to get it to/from the barn --> garage (as presently both the in/out main lines from the hydraulic pump have failed) Is there a tell-tale way to know what rebuild kit I need if I have the serial/model number off the tractor? I've had to wrap a wrag around the column this summer to limp by until fall came and it was no longer needed for mowing. I'd far more up for spending a little $$$ on a rebuilt kit, or simply replace the steering valve.... vs. buying a new machine, even if this thing has a few quirks about it, like the brakes no longer work, and all the safety measures have been removed by the PO. Thanks! |
#75
I'm pretty sure the kit listed will work on your 1872. Here is the spring kit that will be needed also if they go flying across the room.
#76
FWIW:
I went to my beloved Deere dealer for the kit, as it was 6 miles away, less expensive and in stock a few years back. Also the Jesus springs were in stock for us old fumble fingered mechanics with not only poor hearing, but poor eyesight and memory problems as well (just an FYI for others that might want to know there IS an alternative to the mothership Kub kibbits IIRR Parker is the manufacture. That steering unit was popular but now we will be seeing more and more "electric" steering assemblies as we regress to darker times of Gubber-ment controls. |
#77
"replace the steering unit" if they are available, and you have more money than you need, by all means that would be easier.
#79
So, while I'm already making a mess of things adding the rear end braces from xtreme, I also ordered the seal kit from Messicks. It's now 70 bucks.. not 50..
SO, hopefully with these two items I'll be back moving and mowing again. My seals only leaked ones the unit got warm, it wasn't an 'always' deal.. not much of a problem plowing snow, but mowing in the summer it would start to weep out the top of the steering column about 1/2 way thru my mowing job. Fingers crossed. |
Thread Tools | |
Display Modes | |
