1863 Gas tank bushing replacement
Getting ready to replace both sides. Do these just pry out and then push in the new ones? I’m assuming you get the new ones in place and then push in the fuel shut-offs?
If they won't pull out I cut the rubber, pull the shut off out then fish the cut off part out of the tank. I put a little grease on the out side of the new bushing, push it into the hole in the tank then a little grease on the valve and push that into the bushing.
More info here
https://www.onlycubcadets.net/forum/...ad.php?t=33244
Thanks for the info Sam, gonna do this tomorrow!!
Got these replaced this morning, no runs drips or errors!!! Also found the source of my hydro leak, two upper bolts on each side behind the wheels were finger loose nearly. Tightened 'em up and not a drip overnight!!
Thread Tools | |
Display Modes | |
