Greg Rozar AKA- CubDieselFan
Old 04-13-2019, 10:27 AM
Marko141's Avatar
Marko141 Marko141 is offline
Default 127 no reverse
Well the time has almost come to address and issue. I have been tied up house projects, drive shaft on my X3 bmw, and work so now I need to crack down on my 127. It’s been a great running tractor but little by little the reverse worked less and less and now there is no reverse at all. I thought maybe a valve on top of the rear end but I’m thinking it’s a linkage issue now. On the “driver side” the side with the forward and reverse lever, I can look between the fender and the tire through a whole and a lever moves in there when shifting. I’ll take a photo of it but it doesn’t not look like it is engaging fully in reverse. Also the tractor sputter forward and wines when the tractor gets turned off. Any suggestions are great, any photos or diragrams would be best.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 04-13-2019, 03:13 PM
Merk Merk is offline
1. When was the rear end oil and filter change?
2. What oil and filter was used in the rear end?
Another area to check is the speed control linkage. It could be out of adjustment. Page 2.43 and 2.44 of a chassis service manual ( https://s3.us-east-2.amazonaws.com/c...ervice+Man.pdf ) shows how to adjust the speed control linkage.
Manual was found in OCC tech section.
Project Uncle Dick
Cub Cadet 70
Old 04-13-2019, 03:41 PM
Marko141's Avatar
The oil and filter were replaced last year. Crossed the numbers from the filter that was on it at NAPA.
Photo of where I think the issue is.
File Type: jpg AED45370-3BD5-4B84-9197-A20174C5022D.jpg (28.9 KB, 136 views)
File Type: jpg F9017508-B8B1-4CCA-9B67-18D2C2C59ACC.jpg (29.7 KB, 137 views)
File Type: jpg 5EFA8461-AF35-4C3C-8028-C42DEB738F07.jpg (27.6 KB, 135 views)
Old 04-13-2019, 09:59 PM
dodge trucker dodge trucker is offline
my 129 has same issue, only that one has no neutral or reverse, just forward... partly why I'm swapping hydros with a ported one I have here from a 1650... the other reason, is to have hyd lift on the 129.... have not had the tinwork off the 129 yet, if the issue on mine is external to the hydro, I'm hoping to see the "why" when that comes off..... if I see something that looks out of place, I'll report back/might be same cause of your issue.
Old 04-13-2019, 11:06 PM
Marko141's Avatar
That would be helpful, thank you
Old 04-14-2019, 05:23 PM
The creeping forward at shut off is known as hydro creep. You probably need an adjustment there. The NO REVERSE, but you have forward motion is likely due to your relief valve being clogged or stuck. I would try those first and see the outcome. The 127 is not a fun tractor to address these relief valve issues because it is a NF, but if you remove the fender pan, set the tractor up on jack stands and then investigate these valves, I think that would be very helpful to resolving your issue.
Old 04-14-2019, 07:14 PM
Marko141's Avatar
Thanks for the information, I’ll have to try it.
Old 04-20-2019, 07:49 AM
budscub's Avatar
budscub budscub is offline
Default Adjustment
Do the photos show the position of the cam ( trunnion) plate in each position ( i.e. One photo is fully forward position, one is fully reverse direction and one is in neutral.)
If so it appears you are not getting enough movement on the trunnion when going into reverse.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 04-20-2019, 11:01 AM
Marko141's Avatar
One photo in each position. That’s why I was thinking linkage was my issue. Haven’t had time to take the tractor apart. Been busy with some other projects.
Old 04-21-2019, 07:46 AM
cubs-n-bxrs's Avatar
As well as the rod ends in your forward /reverse linkage I would take a real close look at the springs that are in your damper plate. On my 682/782 the reverse over the course of a couple years got to be almost non existent. After taking it apart I found a bad rod end and the springs in the damper plate had almost 3/8th inch end play. The pin that rides in the slot you have pictured on mine was almost worn in half so I filled the worn area with weld and filed it back to the correct size as well. I corrected those issues and wow what a difference. Good luck
