Greg Rozar AKA- CubDieselFan
Old 02-26-2019, 03:05 PM
King47 King47 is offline
Default Compressor /sandblaster recomendations
Hello, I am new to the board and I just picked up a cub cadet 106 which I intend to restore as well as use.
I am wondering what compressor/blaster set ups people use? I never tried a restore and currently my knowledge of the Cubs is very limited. Heck, I am still trying to figure out what year it is... the last two digits is 71 so it may be a 1971?
I have looked through the fourms for the last week ir so gathering intel and parts ect. Some of my questions may have been asked already but please go easy on the Rookie..lol
Thanks-Matt
File Type: jpg EC531426-FA77-40C7-B1F2-B335F5FAC727.jpg (29.5 KB, 178 views)
File Type: jpg A384DF6E-31F9-4AAB-BD0C-92DEE922303A.jpg (29.5 KB, 179 views)
File Type: jpg 666DB61F-A7AA-4856-8FD2-E6BA3CCD0C6E.jpg (25.6 KB, 177 views)
Old 02-26-2019, 03:32 PM
ejl6658 ejl6658 is offline
I am in the process of sandblasting a 54" mower deck. My setup works very well for sandblasting rust, paint, and powder coat.
Compressor
https://www.tractorsupply.com/tsc/pr...r?cm_vc=-10005
Media
https://www.tractorsupply.com/tsc/pr...s?cm_vc=-10005
Sandblaster
https://www.eastwood.com/ew-100lb-pr...e-blaster.html
Old 02-26-2019, 03:34 PM
First, welcome to OCC.....
The compressor must be equal to or greater that the CFM and PSI you plan to use the sandblaster for, ie: 4CFM @ 100 PSI, etc.
Roland Bedell
Buy: Made in the USA
Old 02-26-2019, 05:36 PM
Roland he has a 106 and got the 71 from the data plate. It’s not a model 71 although the year may be right.
Welcome king, Roland or someone will be around to look up month and year made for you. Your serial is hard to read but built from 69 to 71. I’m sure it was just an oversite. Lots of knowledge on these tractors here.
I personally am going to look intot the pressure washer sand blaster attachment. Have heard good things about some of them and no dust!
Old 02-26-2019, 06:57 PM
Roland is correct on having an air compressor with a high enough CFM output. My compressor is 15.8 cfm @90 psi and the Eastwood blaster requires 10 cfm @90 psi. I can run 100 lbs of abrasive thru the blaster and not have to stop and wait for the compressor to catch up. If your compressor is undersized you will spend more time waiting on it than sandblasting. BTDT.
Old 02-26-2019, 11:40 PM
Thanks for the replies and the links. I will look for a compressor that will match the cfm for the compressor amd blaster. I will need to find a more economical compressor for now.
Sorry for the bad pic if the serial #. It is 2050037u375571
I hit all the bolts with pb blaster and. Will start taking it apart over the next week or so. There is quite a bit of informationon this site!
It should be a fun project and I am eager to get started. Cheers
Old 02-27-2019, 06:36 AM
Sorry, I misread your model.
Yes, it is a 106 made in Feb '71.
Roland Bedell
