Mowing deck compatibility
I have a Red IH 682 with a well rusted 50" mowing deck. I have located a yellow MTD Cub 682 with a good 44" deck. I would sure like to know if that deck will work on mine before driving 100 miles to see it. Appreciate any help
First, welcome to OCC.......
The 38C, 44C, and 50C mower decks will fit and work fine, on your 682.
Deck for 682
Thank you for your reply. I know a 44C deck will fit my IH682, do you know if the 682 made by MTD used the 44C deck? The tag is unreadable on the deck of the MTD Cub 682. If it was closer I would just go and check it out, it will be worth the trip if I am reasonably sure I can use the deck. Thanks again for your help
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
682 mowing deck
Thank you for the info. I think I will make the trip and check the condition of the MTD 682. By the looks of the picture it should be worth $500
Safe travels. Take some pictures for us
Thread Tools | |
Display Modes | |
