Greg Rozar AKA- CubDieselFan
Old 06-29-2022, 04:03 PM
Default M20 Flywheel
Working on my Son's Kohler M-20 Engine. I am "attempting" to remove the flywheel. I have already broke a Puller, and for the life of me, can't seem to get the flywheel to budge.
Does anyone have any tips, tricks, or advice ??
Roland Bedell
Buy: Made in the USA
Old 06-29-2022, 05:04 PM
Are you using a harmonic balancer puller?
Old 06-29-2022, 05:08 PM
Yup....
Roland Bedell
Old 06-29-2022, 05:33 PM
Farmall450's Avatar
Bigger hammer?
Old 07-04-2022, 09:54 AM
Any luck yet Roland?
Old 07-04-2022, 02:09 PM
No luck as of today (4th).
Roland Bedell
Old 07-04-2022, 07:33 PM
Farmall450's Avatar
Can you safely put some heat on it?
Old 07-04-2022, 08:25 PM
I can, but don't know how much is "safe".
Roland Bedell
Old 07-05-2022, 10:32 AM
Farmall450's Avatar
Neither do I, but it's gotta come off, right? Hardest think I had to pull was the crank pulley on a Farmall C; took a big 3 jaw and a lot of heat before it blew off of there.
Old 07-05-2022, 11:43 AM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Little bit of heat, load up the puller, and rap the drive screw with a few toots of the air hammer?
