Greg Rozar AKA- CubDieselFan
Old 02-13-2019, 02:16 PM
hondaxr hondaxr is offline
Default Cub Cadet 127 wheels dont turn
I have a Cub 127 with a snowblower on front was using and suddenly wheels stopped turning! Referring to Manual - Chassis Service, 1x6/7 Series page 212 Illust. 2-7 my drag link works(moves) fine and top Drag link arm moves too! But drag link arm UNDERNEATH does not move nor does TIE ROD that moves right wheel also! How to fix?
Old 02-13-2019, 04:12 PM
cooperino's Avatar
By turn, I am assuming you mean steer right to left not turn as in rotate. If it was steering fine and just stopped. I would imagine snow and ice build up is the issue. Thaw it out and see what happens. If still not steering when thawed out then i would start looking at steering components and steering box.
Old 02-13-2019, 06:20 PM
Sounds like a sheared pin in the drag link arm.
If the drag link moves when you turn the wheel, and the tie rod don't....
Old 02-13-2019, 07:23 PM
DieselDoctor's Avatar
Somebody that can't look at the pieces and figure this one out for themselves shouldn't own a 40 year old garden tractor!
Old 02-14-2019, 06:33 AM
This is my suggestion. Remove the Drag Link from the Steering Gear Assembly. It will reveal the problem, that is in (A) the Steering Gear Assembly, or (B) the Linkages from the Drag Link Forward.
Roland Bedell
Buy: Made in the USA
Old 02-14-2019, 05:43 PM
SHEARED ROLL PIN! Actually was an easy fix! Put new one in greased up and working fine now! Thanks to all!
Old 02-14-2019, 05:44 PM
I don't own a 40yr old tractor, It's a 50 yr old tractor!
Old 02-14-2019, 06:38 PM
IHscout79 IHscout79 is offline
Good find! Glad you got it fixed!
Justin
Old 02-15-2019, 07:25 AM
Good to hear you found the problem.
Roland Bedell
Old 02-15-2019, 08:54 AM
May I just add there is a difference in COILED pins and ROLL pins.
If you broke a coiled pin and replaced it with a roll pin, it will break sooner than later.
If you don't know the difference, --------
rolled is just that, inasmuch as the ends butt.
Coiled pins are coiled like rolling up a matchbook so there are a couple of turns
inside for added strength.
IH used a lot of coiled pins and little or no, rolled pins.
Just a FYI.
Thread Tools
Display Modes
