Greg Rozar AKA- CubDieselFan
Old 12-22-2018, 06:40 PM
rockne10's Avatar
rockne10 rockne10 is offline
Default New in central PA.
Hi, all; and thanks for letting me join.
I imagine most of you are collectors and hobbyists, with some still relying on your Cadets to keep your estates in order.
I bought a used International Cadet 76 thirty years ago and am hoping to keep it going as long as possible. It definitely shows itself to be a worker.
Just this year it started shutting down after 10 or 15 minutes and I think the coil is at fault. I'm having a hard time finding a coil that fits; and, failing that, I might have to contemplate an engine replacement. Original engine is B&S 170707 1231-01 7210301. Suppliers I've found have indicated that coil is NLA.
Looking for suggestions and/or recommendations.
And thanks again!
Old 12-22-2018, 07:09 PM
Welcome to OCC.....
Roland Bedell
Buy: Made in the USA
Old 12-22-2018, 07:21 PM
athomas's Avatar
athomas athomas is offline
Welcome to OCC hopefully you'll find what you need !
Old 12-22-2018, 07:34 PM
Should be a standard Briggs mag less than $30
Old 12-24-2018, 12:13 AM
dbuck dbuck is offline
Smile
Can not seem to locate a coil number, but that is a points engine are you sure it is not the points? Pts & cond 294628,
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 12-24-2018, 08:57 AM
I came up with part number 298968 for the 170707 Briggs.
Old 12-24-2018, 05:36 PM
Welcome to OCC!
Proud owner of my Original!
Old 12-24-2018, 06:52 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Welcome to Only Cub Cadets!
Old 12-24-2018, 11:07 PM
rockne10's Avatar
First thing I did was two oil flushes, points, condenser and plug.
Assumed it had to be something that was failing when the engine got up to temperature, as it always started immediately and ran 10 minutes or so and shut down. Sit and cool for a few minutes and start right back up, but only for a minute or so.
Coil is second assumption.
I found one online that was purported to fit the 170000 series engines, but it just did not quite fit. Thanks for that part#, Alvy.
I'll try one from another supplier; failing that I may have to resort to dropping in a new engine. Thanks everyone.
Old 12-25-2018, 07:55 AM
sawdustdad's Avatar
Are you sure it's not fuel starvation? Does it quit instantly? Like it was shut off?
Or does it cough and die like it's running out of gas? Does pulling the choke help a bit?
