Greg Rozar AKA- CubDieselFan
Old 12-17-2018, 08:24 AM
yingpin yingpin is offline
Roland,
Thanks for that additional detail. I apologize, I am hoping that this little tractor allows me to learn a lot of things at little to no cost. I am hoping that will be the case and my main reason for buying one that is currently running for cheap.
I ordered the correct PTO switch since I have not found one locally but it will not be here until Xmas eve. I will have questions when I try and redo this portion of the wiring.
Decided to pump out all of the old gas, it looked pink when I pulled most of it out of the tank with a transfer pump. I drained the gas from the carb bowl as well. Pulling the fuel filter this morning and will replace that as well. Hopefully I cAn find that replacement locally (could not find the part number from an online parts diagram). My hope is to get that system cleaned up and put some fresh gas and get it started again.
Old 12-17-2018, 09:01 AM
The Fuel Filter is Kohler KH-25-050-02.
Roland Bedell
Buy: Made in the USA
Old 12-17-2018, 10:14 AM
You have all of the info! Not sure where you pulled that but I am having a hard time tracking one down by that number, looking for an alternate part as a suitable replacement.
Old 12-17-2018, 10:45 AM
Sorry, KH-25-050-02-------> is now KH-25-050-07-S.
Roland Bedell
Old 12-17-2018, 03:53 PM
Is the shifter on the side of the steering wheel??? They have a habit of wearing out and jamming... fyi...
Missed your message early in the thread. It is set up like this. Is there anything that can be done to prevent or lessen the likelihood of this occurring. It seems to shift ok now
Old 01-01-2019, 08:55 PM
The correct PTO Switch (925-0893) has Five (5) terminals to it.
Attached is a 1715 Start Circuit Diagram. IF......it is wired correctly and has the correct parts. It is drawn in the proper sequence and wire color codes.
IF......everything is wired correctly and you have the correct OEM parts, then the proper starting sequence would be to have the Brake Pedal Depressed, the PTO Switch in the "off" position, then the Starter Solenoid will engage once the Ignition Switch is turned to the start position.
BTW. The blue wire you reference is for the Lights and has nothing to do with the Start Circuit. (That is assuming the wiring hasn't been modified)
R Bedell,
Thank you for the information you provided thus far and I apologize for my ignorance with the wiring process. I received the new and correct PTO and I had a quick question. The wiring diagram I have lines up the terminals in a different fashion than the actual layout of the switch. I was wondering if your wiring diagram is different or if we can "label" the terminals to the appropriate wire?
Also, the gauge cluster is present but there is no wiring harness to connect it too. If I am understanding the wiring diagram. The PTO switch C terminal and the Key Switch S Terminal both connect to the Neutral Indicator. I am assuming that is within the gauge cluster?
As you can see, I am probably in no position to work on this thing
File Type: jpg 90DD252C-7DC2-48E5-B935-AFA2D0C12688.jpg (32.1 KB, 41 views)
Old 01-01-2019, 09:05 PM
Show me a picture, of the back of switch, that you got.
Roland Bedell
Old 01-01-2019, 09:55 PM
Here is the switch, not sure why it loaded sideways but. The 3 terminals are at the bottom in the off position and the two on top in the on. Looks identical to the one you pictured. Just trying to determine what goes where.
File Type: jpg 4EED9AAD-7F5D-446E-8E07-0DE24DC12F17.jpg (23.3 KB, 40 views)
Old 01-01-2019, 09:59 PM
Depending on the Vendor that made the switch, here is an Alternative Diagram.
Roland Bedell
Old 01-01-2019, 10:03 PM
That would be correct.
The Neutral Switch is located under the Dash Panel. It would have three Red Wires going to it.
Roland Bedell
