Greg Rozar AKA- CubDieselFan
Old 10-29-2018, 08:51 PM
Sounds like a defective ignition switch.
Ditto......
Purchase and install the correct Ignition Switch - IH-394771-R93
Thank you Roland. It Seems like I posted with the invisible ink option , but yes, what WE said.
Get a new switch... and you should be good to go.
I agree, you need a new ignition switch.
Old 02-15-2019, 11:10 AM
crazycubtrio crazycubtrio is offline
Working stiff did you ever get the starting issue fixed? If so great if not I have seen the same thing happen to a 1200 I had a while. If two of the wires get flipped around on the ignition switch it will do what you are saying. The power wire to the voltage regulator should go “dead” while cranking and the wire to the coil should stay hot during cranking and the run position. These could also be swapped at the firewall connector as well. I know this is a late post and hopefully you already have it repaired
Old 02-15-2019, 04:11 PM
Workingstiff Workingstiff is offline
Actually, its been a very very crazy time for me. My Dad took a tumble down a full flight of stairs and long story short. He's moved in with us and not driving anymore.
But,no I haven't fixed it as yet. But that sounds very plausible and very easy to try the next time I think about it when I'm out there. Thanks
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 02-16-2019, 09:13 AM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default cranking
One of my 149's did the same thing a year or so ago. Turns out it was the switch that had gone bad. Aftermarket replacement switch cured it. Sorry to hear about your Dad. Have a great day.
Bob
