Greg Rozar AKA- CubDieselFan
Old 02-15-2019, 10:39 AM
On the lift bar...
Are you sure you do not have an issue with slag goobers on the side of the transmission case like this??
This was on my 126 and about drove me nuts till I split the tractor and found it.
Old 02-15-2019, 02:35 PM
Another thing.
If you have not yet installed the lift bar, and that is the correct terminology for the piece, Check both ends where the holes are for distortion.
This, IMHO, is caused from shearing the mat'l during production as well as punching the holes in each end.
You will likely see a slight "tweak" or bend at the very ends of the bar.
Eye ball it, should be noticeable if present.
This will provide just enough added drag when installing and operating to give you trouble while installing.
I ran across this with my 147 just the other day while installing a 3 point unit. I got it in there but it was very tight in operation. Removed the bar and un-tweaked each end a bit in the press and it practically fell back into place.
When installed, the 3 point ass'y should operate very freely w/no to very little drag. A little drop of grease on the lift bar spacer as well as making sure the spacer is not worn to the point if being ineffective should produce a drag free ass'y when installed.
removing the hangers on each side of the rockshaft, in the case of the 147 series will also aid in installation as well.
