Greg Rozar AKA- CubDieselFan
Old 09-06-2012, 10:16 PM
That's awesome, Jeff! Congrats!
Proud owner of my Original!
Old 09-06-2012, 10:37 PM
Thanks. Can't wait to get it home.
Old 09-07-2012, 08:17 AM
jkier's Avatar
jkier jkier is offline
I need to upgrade my lathe!
I have an identical Mill/Drill made by ENCO, but you've got me beat with tooling
Does this mean we can expect billet aluminum under-drive Cub deck pulleys and lightweight engine blocks?
btw: Are you still making brinly hitches and those tiller extensions? I'm in need of both
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 10-23-2012, 10:15 PM
Still making heavy duty sleeve hitch adapters and tiller adjustment parts. I could make extensions ( you supply tines )
Old 10-23-2012, 10:16 PM
10" four jaw chuck for the Monarch
Old 10-24-2012, 12:55 PM
Excellent work, as always, Jeff!
Old 03-30-2013, 10:27 PM
davekamp's Avatar
davekamp davekamp is offline
Default Excellent choice in lathes!
Excellent choice in lathes, Jeff. I believe that's a CK-series. I've got a 10EE, and it's the sweetest machine on the planet. What I can't cut with it, I cut with a 24x210 Lodge and Shipley... which isn't quite as precise as the 10EE, but it does the trick.
Did someone say drill press?
It's a Johannsen radial, fitted with a Bridgeport BRJ head, but using a 2hp Baldor 3-phase motor, driving the spindle with a Carlisle RPP toothed-belt setup in 3:1 reduction. Motor is driven by an Allen-Bradley 1305 type AA12A variable-frequency drive, fed by a 240v single-phase 15A receptacle. Full speed control from stopped spindle to just under 2000rpm (motor's spinning at about 6000rpm)... and I've equipped the drive with additional braking resistors for dynamic braking... when you stop the spindle, it stops NOW! Motor's mechanical fan has been removed, and replaced with a 240v computer-type 'muffin' fan, so it's whisper quiet, even when drilling a BIG hole. I've also fitted the table with an electric gearmotor for changing table elevation. Also have a footpedal with two-stage control for power-tapping, and a pair of LED floodlamps that power up anytime the controls are on.
Old 09-13-2014, 08:46 PM
Default a "new to me" power hacksaw
Latest addition to my home shop, a Racine power hacksaw. I need to locate an electric motor for it but other than that, it's ready to go
That's a yardstick on it. There is a whole lot of cast iron there, it must weigh well in excess of 300 lbs
Old 09-13-2014, 10:10 PM
That's cool Jeff!
Predecessor to the bandsaw!
Old 09-13-2014, 11:03 PM
chris hall's Avatar
chris hall chris hall is offline
nothing like having your own tools.looks like you have quite a few toys to pay with.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
