Kohler Field Improvement Package??
So what is this field improvement package (from IH for the Kohler engine) that I see listed for sale on Cub Cadet Specialties website? It is a bunch of random looking parts with no description on what it is for. Just making sure it isn't an upgrade that I need to make sure I do.
Thanks, |
The field improvement package was a kit offered for the narrow frames, wideframes, and quietlines (although quietlines had them most commonly) it had an upgraded muffler clamp, an air filter reinforcement, a plug wire clamp, and a heavier top baffle. Tractors with the plug wire clamp tend to have extremely messed up head studs.
The plug wire clamp is basically self explanitory.
The muffler clamp just allows for better hold on the muffler. The air filter reinforcement is really important, it keeps the 3 holes in the carb from vibrating and stripping out. I would definitely buy a reinforcment. The top engine shroud basically allows for better cooling by letting more air through. |
while making something from heavier gauge makes sense in one hand, The other hand, maybe not so much. A heavier gauge weighs more, thus you are shaking a bigger mass, straining @ the mounting points. Thinking: just repair & reinforce the weak or mounting points areas of the original cooling box. -----Just my thoughts. |
Make a muffler crutch to go from the muffler mount to the motor, this'll keep the stud from breaking off, and also make an air filter reinforcement.
What does the air filter reinforcement look like? Does it support the air filter housing to relieve the moment (bending force) that the filter housing exerts on the carb? Anyone got a picture?
It looks like this, it goes on the inside of the air filter housing to prevent damage.
For this field improvement kit, I assume that there was was a service bulletin issued? As if there was some sort of problem with some tractors (models 800, 1000, 1250, 1450 and 1650). These Cub Cadet tractors all have different Kohler motors ranging from 8HP up 16HP. Am I correct? If so, what was the problem?
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
