Guys, can you confirm what I "think" I know about my Cub?
From what I've researched from the serial number, I believe my Cub is a 102 made in '67.
Would appreciate it if someone would look it up and confirm or correct me. Thanks! |
Does it have a K241(10hp) or a K301(12hp) in it ?
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
Ditto, I agree. It is either a 102 or 122, depending on engine size.
Ive never seen that before where 2 differnent models use same set of serial numbers. Does anyone know if it was an even split? Equal number or close amount of 102 and 122 tractors built
That's how all of the IH tractors were, even the big tractors. When the 6/7 series came out, they started adding a model number to the tag so you could identify the tractor.
Will check....
IH did not have dedicated assembly lines. Tractors came down the line (ie: 71, 102, 122, 123) in no particular order, and were assigned a sequential serial number as they appeared. Maybe IH ran 71's on Monday, 102's on Tuesday, etc.........
Based on the size of the fuel tank, I would say you have a 102. But we all know things like that are easily swapped out over 50 years.
That's how all tractors are.
This is my understanding as well.
"Equality is about giving everyone an equal chance, not about giving everyone an equal result." 1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator http://www.onlycubcadets.net/forum/s...ad.php?t=50159 |
Thread Tools | |
Display Modes | |
