Hood Latches
Can somebody tell how these are supposed to work? The one on the right side works fine, but the one on the left side hits the PTO control before it's all the way down. Is this latch bent or is something else wrong.
Pat Benner Haskell OK Keep the Deck down and the Throttle open!!! |
Amigatec:
What model of Cub are you working on....??
129 and 149.
Amigatec,
Both my 149 and 169 are the same way you have to kind of twist them a little so you get it to go past the pto lever. Same thing coming back up through. There is a nut up under the side where they are mounted that you can loosen a little, sometimes that helps. Gives them a little side play. |
Thanks I'll try that.
