So Much For The "Walbro" WHG Myth!
When I got a 1450 with a Walbro WHG carb, I shelved the carb, because of all the stories I have heard about them.
Well, my K301 was in need of a carb, I am trying to get the original right. I slapped the Walbro WHG "52" on the K301, and the engine works perfectly! I did not even touch an adjuster yet It idles It accelerates It has perfect power It even appears to have a home made linkage. The choke works backward, no biggie. I might stick with the Walbro!! Have you used a Walbro? |
Glad the carb worked for you!
Allen Proud owner of my Original! My Grandpa's Cart Craftsman Lawn Sweeper Craftsman Plug Aerator |
Your lucky. I tried three different walbros on my old 1650 and they all idled and seemed to rev happy. Unil I tried mowing or moving and it didn't have anywhere near he power of a 10 horse let alone a 16 once I hunted down a good kohler carb it was like a whole new machine .
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
that's what I always found. they run great in the shop. take them out for a drive even on a hill they fall off and don't recover well at all compared to a Kohler carb
Well, recently I have learned something about Walbo Carbs.
I was always under the impression, that the Walbro Carbs, that Cub Cadet used, were the "fixed main jet" design. Not so, the WHG series is an adjustable jet carb and Cub Cadet did use this series of Carbs on various tractor. Now, I have not heard and positive or negative reviews on this series but it is interesting to discover this Walbro Adjustable Carb.
The idle needle is all the way to the left in the pic, in the same location as the Carter/Kohler. And, of course, there is the idle speed screw. |
even those don't have the torque that you get with the Carter or Kohler . We always called them wheelbro's. if you put them on a flow bench and hook up a water monometer and play with it enough you can improve them.
Is this a walbro?
I have been reading through threads and I cannot tell what kind of carb this is. I finally snapped a couple of pictures of it. It needs rebuilt so I was trying to figure out if I should rebuild this one or find a Kohler carb for the K301.
1981 IH Built 782- 44" deck 1650 dual stick 71 "121" round fender and replacement k301 carlisle tru powers and v61 |
My FIL put a Walbro adjustable jet carb on his 149 sometime prior to his death in 1992. I have had that Cub since then and it has performed great and I have not had to do anything to it.
___________________ Jim 782 w/Command 18, 1862 not running; IH 42 inch blade; off brand cart |
Well the parts 100 came with a walbro on it and i happened to have a carter on the shelf that i knew ran good but i don't fix stuff thats not broke. One evening i jumped on it like i did once and a while to mow or pull another tractor out of a hole whatever it was i dont remember now but got the the end of the drive and it dies just like you had turned off the key. So of course i check for fire it had plenty no problem said well ill change plug for good measure check timing blah blah blah... just never ever had one die of a gas problem like that before was total odd. So after all that i said well maybe its gas related... pulled breather didnt smell any gas was like weird choked it nothing was like well float must have stuck. Gave it. Love tap or too no help pulled the carb bowl while on the tractor flat was working there was gas there and put it back on same trouble, I might add the bowl was spotless no trash that i could see! Got a manual spray bottle of gas and put a squirt or too in the carb while turn it over and as long as i pumped the fuel in it would run great pulled the carb put the carter on and it run as good as it did before? Have never had that kind of problem ever with any type of carb... still havent messed with the walbror as i dont care to have that kind of no warning not working problem if i dont have too! Good luck with it!
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
