Greg Rozar AKA- CubDieselFan
Old 09-21-2009, 11:52 AM
TBell TBell is offline
You guy's are awesome! I never even gave the drag link a though. I was ready to pull the steering box when I got it into the shop. It's interesting to see the differences and the versatility of these machines compared to what else is out there.
Thanks again
Terry
Old 09-21-2009, 03:15 PM
ajgross ajgross is offline
Inactive Member
With your relief valve problem. You can take them out and manually push them back up. I use a small allen wrench and push the punger up from the bottom of the valve.
AJ
Old 09-23-2009, 08:24 AM
Another update. Last night I finally got the beast to move forward. I hosed everything down a couple of times with penetrating oil (KROIL to be exact) this stuff makes PB Blaster look like water, fired her up and moved the lever forward a little bit and brought the engine up to half throttle. While the pump was building a little pressure I adjusted the carb so it doesn't have to run on full choke any more (I know Sammy Safety would give me a big ticket for this but....) , by the time I turned the screws it started creeping forward, pulled to neutral, hopped on and away we went! I will pick it up this afternoon and as soon as I get it into the shop I will post some pics.
Thanks for all your help, I'm sure I'll have a few more questions soon.
Terry
Old 09-25-2009, 07:53 AM
As for the steering issue... The weld on one side of the mount for the steering box is broken. When turned to the left it pushes the bracket into position and bumps the remainder of the weld, to the right there is nothing to stop the plate from moving. It won't be the most fun to do, but I think once I get my arm to bend backwards three times I should be able to get a couple of nice beads of weld on it, and the other side just in case and be in decent shape.
Terry
Old 09-25-2009, 08:42 AM
RPalmer's Avatar
RPalmer RPalmer is offline
TBell,
I don't know what you have in your shop but you might be able to hook the likes of a chain fall on the front of your Cub to lift it and make that weld easier to reach.
Old 09-25-2009, 01:40 PM
I have it a work and plan on using the fork lift to get it well up in the air, we have "jack stands" for the boom to make it quite safe to work under it. Just have to remember to remove them before you try to let the mast down and wonder why the h-ll it's not moving. That will make it slightly easier but only slightly.
Terry
Old 09-26-2009, 12:32 PM
Default Photos!
Finally fixed the steering bracket, now to adjust the drag link to really even it out. Thought I would get a few photos up and ask if anyone can post a pic. or link of what the grill looked like?
Heres some shots from all sides
All in all I think it's in great shape, all the decals and tags are still in great shape on the motor and for $200.00 I pleased.
Terry
Thread Tools
Display Modes
