Greg Rozar AKA- CubDieselFan
Old 12-11-2018, 11:25 AM
AL Farmall Boy AL Farmall Boy is offline
Thank you all for the responses and suggestions. I will look into all of these and think that I will just get some regular machine screws, nuts, and star lock washers for the muffler box, then I'll get some thick rubber washers to use to fasten the side panel thumb screws down.........speaking of,
what size hardware do I need to assemble the muffler box, and what size thumb screws are needed for the side panel?
Mine were either broken off or missing. I presume I would want longer thumb screws if I use the rubber washer.
Old 12-11-2018, 05:44 PM
twoton twoton is offline
Originally Posted by Mudrig150 View Post
The trim edge strips require modification to the hood if they're too thick, mine is from kurk and pushes the edge of the dash in and prevents the hood from closing entirely.......
...then you need to loosen the 4, 3/8" bolts that hold the casting to the frame and adjust it till it does close entirely. You may also have to adjust the back hood support plate/latch.
Old 12-11-2018, 06:45 PM
Mudrig150 Mudrig150 is offline
But then it doesn't line up. I've tried with it full forward and back, but either way the trim strip catches and makes it hard to close and impossible to open the hood. I know that the grille casting is cracked a bit and bent, maybe that's the issue. I think the bent hood doesn't help either.
Old 12-11-2018, 06:48 PM
Hey Mudrig, where's that list you were putting together...
Old 12-11-2018, 06:57 PM
Here, lemme look real quick...
Ah, here it is!
https://www.onlycubcadets.net/forum/...ad.php?t=53571
Post #13.
Old 12-11-2018, 09:40 PM
That is awesome! Thank you!!
