CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
OCC Archives
Old 06-02-2021, 09:02 PM
IHinIN IHinIN is offline
Default Shop press build
I’ve been wanting to buy or build a hydraulic shop press for years. I recently came across some free 5” channel iron from a machine skid that was being scrapped at work. It was the perfect size for a 20 ton press. I also got some free 2” angle iron for the base. I added a winch for raising and lowering the bed. Instead of the usual bottle jack like most shop presses use, I went with a 20 ton x 4” stroke cylinder and an air-over-oil 10,000psi pump. The cylinder is mounted on a trolley for the rare occasions when a part can’t be centered in the press. The ram has a reversible tool that’s 2” on one end and 1” on the other. I also made several ram tools with dowel pins: 5/16”, 3/8”, 1/2”, 5/8”, & 3/4”. The one side was intentionally left hanging out because I plan to build a manual arbor press there. And of course it’s painted IH red.
File Type: jpg 9E7576D1-9282-41AC-B0CB-2ACA3AD16148.jpg (34.8 KB, 106 views)
File Type: jpg B4C96E13-AA93-459A-9326-4184DA666A8E.jpg (35.1 KB, 106 views)
Old 06-02-2021, 09:17 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Nice work, should come in handy.
2-1811's
1872
2072
Old 06-02-2021, 09:41 PM
Ambush Ambush is online now
Very nice build and a very handy tool! Its amazing the iron work that becomes possible when you have a capable press and some tooling.
Sure saves a lot of work and damaged parts from the BFH episodes.
Old 06-08-2021, 01:42 PM
SGragg's Avatar
SGragg SGragg is offline
Great job on the press. I particularly like the hydraulic cylinder and the wheels for mobility. Great idea!
And, of course, it's made in the
Stanton
1980 IH 782, Kohler M18
1983 CCC 782, KT-17 series II
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 06-08-2021, 06:41 PM
Thanks guys!
I plan to build a finger brake for the press similar to this.
File Type: jpg B9A36AD9-8D64-4BE6-893B-D5036388DD1E.jpg (11.8 KB, 61 views)
Old 06-13-2021, 08:57 AM
john hall's Avatar
You need a storage rack on the other side to counter the weight of the arbor press!! Seriously, a storage rack for all the plates and push blocks would be handy, amazing what tends to accumulate with these, and I still have to turn something down quite often.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 06-13-2021, 09:54 AM
Great job as always Adam. Where did you get the cylinder & pump at? I have one of those cheap China made jobbies that was given to me but I like yours much better.
Old 06-13-2021, 06:38 PM
John,
I added the shelf on the left side to hold tooling as well as the pump when it’s not being used. I have a 50 cal ammo box there now for the smaller tooling. I’m waiting on a guy to burn out a couple of arbor plates. I plan to add a jack or a fifth caster under the tooling shelf for support when using the arbor press.
Oak,
I found the cylinder and pump on Amazon. Also had to buy an 8 ft hose since the pump comes with only a 5 ft hose. The pump is a Temco brand. It has a 5yr warranty for just a little more $ than the generic no-name pumps. Their 20T x 4” cyl was out of stock so the one I got is a Hydrafore brand I believe. I had to change the fitting on the cylinder because it wasn’t the same size as the one on the hose. Luckily the pump came with the fitting I needed.
Old 06-13-2021, 10:38 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
IHinIN
Thanks for sharing your idea's.
I have a Press,
I got as a Birthday Present years ago.
It has served me well.
Other-wise saying,
I have made due with it.
I have always made a list of improvements,
That I would like to do as I have seen video's or post in forums.
I will add the Ammo box to my list.
Thanks to You IHinIN
Finger Brake is on my list also.
One similar to S W A G.
You have (Nailed It) in one package.
I like the Arbor press addition.
Here is one of the idea's I will share that I will do to mine.
This is for the stability for the Arbor Press.
I know this is for a Bridgeport mill but the concept will
work for this, and raise the casters off the floor.
Link: https://www.youtube.com/watch?v=8sPyBSq8Sj8&t=227s
Hope this helps
Copyright ©2000 - 2021, vBulletin Solutions Inc.
