Greg Rozar AKA- CubDieselFan
Old 11-05-2018, 08:48 AM
Good Greif, Man...
You need to make some more room in there, at least clean house.
By the looks of that place, you have more than enough projects under way to start another.
How in the world can you work in the middle of that mess??
Old 11-05-2018, 08:51 AM
Vrobert's Avatar
Vrobert Vrobert is offline
Good Greif, Man...
Oh, how I miss my mum! That sure takes me back.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 11-05-2018, 09:07 AM
Mudrig150 Mudrig150 is offline
Good Greif, Man...
None of the other tractors are mine. Their my brother's. We usually pull them out to get them out of the way.
Old 11-05-2018, 09:02 PM
sawdustdad's Avatar
If the impact driver fails to remove the foot pad bolts, you can cut better slots in the bolt heads with a cut off disk in a grinder then use a BIG screwdriver with a wrench on the shaft, or, a last resort, weld a nut to the top of the bolt. Weld it through the hole in the nut. Usually use a 3/8-16 nut. It WILL come off at that point.
Old 11-05-2018, 09:32 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by sawdustdad View Post
I weld a nut to the top of the bolt. Weld it through the hole in the nut. Usually use a 3/8-16 nut. It WILL come off at that point.
Agreed... welding the nut to the bolt head does work well... been there done that!
Jay
Proud owner of the following:
Old 11-05-2018, 09:59 PM
Bamafan's Avatar
Bamafan Bamafan is offline
Same here, what they said. They can be a PITA.
Larry
Old 11-13-2018, 12:25 PM
In the works of buying an aluminum grille casting and headlight switch, maybe a muffler if the guy doesn't sell it with the engine. 60$. Now to talk to another guy and get my nice hood. One observation I've made is that the grille casting is either warped or bent just enough to cause the hood to barely rest over the dash. The hood is not much better, it's bent so much in the back that, when on the floor, one back corner is an inch off the ground and the other is on the ground. No matter how much I bend it, it's always crooked. Also the dent is annoying.
Old 11-14-2018, 07:25 AM
In the works of bargaining with a guy for an aluminum grille casting, headlight switch, throttle cable, and possibly a nicer muffler, as the muffler I got for 60$ has the opening broke off and the bracket to hold it up is starting to break off. Another person also has a toolbox from Xtreme but he keeps insisting one guy is going to buy it, but like me, the guy buying is full of @$## and he waits until you pack it all up in a box, get it weighed, and ask for the money before realizing shipping costs money and backs out.
Old 11-14-2018, 08:32 AM
Leadslingingdaddy's Avatar
How true that is.....
Old 11-14-2018, 08:41 AM
You bought a busted muffler for $60!!???
Another $30 or so could have got you a brand new one!
