Greg Rozar AKA- CubDieselFan
Old 05-25-2019, 09:37 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Default Newbie questions
What tach meter tool do you reccomend for single cylinder . Does anyone know if anyone in wny area that cuts tires.
Thanks
Old 05-25-2019, 09:42 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
An on tractor tach? or something to just check revs in the shop? I still use a Vibrometer to check governed engines when I work on them, I like the Digitrons for on the track. You can record exhaust temp, rpm , head temp, and wheel speed if you want and play it back.
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
Old 05-25-2019, 09:46 PM
Yes looking for tach to adjust governor at shop
Old 05-26-2019, 09:59 AM
IHinIN IHinIN is offline
I use a non-contact optical tach that reads off of a piece of reflective tape. I picked it up off amazon for less than $20.
https://www.amazon.com/Digital-Photo.../dp/B001N4QY66
Old 05-26-2019, 10:58 AM
Thanks
There is also cheap tiny tacks under $10 on ebay that work for setting rpm's
just wrap a small wire around a spark plug lead.
As far as cutting tires, I try to avoid it, as usually leads to a tube or tire replacement as all the air leaks out quickly depending on the size of the cut.
