Greg Rozar AKA- CubDieselFan
Old 03-18-2019, 08:02 PM
King47 King47 is offline
Originally Posted by ironman View Post
King, no dis intended but it sounds like you have none or very little sandblasting experience.
What you should do is go back and read athomas's post #15. Read it about 25 times because he is spot on about everything. If you still intend to go the sandblast route please be sure to read this...
https://www.cdc.gov/niosh/docs/92-102/default.html
On the other hand, somone has already mentioned electrolysis. It's cheap to set up compared to sandblasting, less messy, and less work. If you don't understand it, read about here...
https://antique-engines.com/electrol.asp
or search youtube for electrolysis.
Whatever you do, have fun!
Thanks for the info! You are correct in my experience using blasters but like most home projects, I am willing to learn and eager to give it a go. That being said, I will look through the posts you recommended and will take all the input into consideration.
I have concisered using electoysis as well as the white vinegar if I can get past the smell.. cheers
1971 Cub Cadet 106
Matt Gallagher
Old 03-19-2019, 10:07 AM
cooperino's Avatar
Just an idea.. Maybe you have a buddy with a large compressor. If you do and you really want to blast yourself. I would suggest you go and rent a blaster. I own one myself but before I did I rented them. The rental place near me rented me a very high quality unit for 40$ for the day. They also had plenty of different medias there and sold them at a decent price. Most times i could get all my blasting done in one day. The one time it did carry over to second day they gave me a 2nd day discount of 20 bucks. Also the rental included a blasting suit and hood.
Old 04-22-2019, 09:30 PM
in my case I was gonna have an "overkill" compressor, blasting or no blasting.... and when blasting it "just" keeps up. 5hp 80 gallon, 2 stage, 18 CFM at 175PSI Emglo upright, It keeps up, but while blasting constantly, it runs the tank down to 90, and pumps and pumps and pumps but itll maintain that 90 PSI all day long. ALWAYS get a compressor that's bigger than you think that you need. Mine is bigger than the one that the tire shop that I worked at at the time, had... same size tank, same motor as theirs, but my compressor head is rated for more CFM's than theirs was.... mine could run an 8 bay shop with impacts, a tire machine and other air tools running all day....
