Greg Rozar AKA- CubDieselFan
Old 05-18-2019, 08:06 AM
Cableguy Cableguy is offline
Default 2166 fuel solenoid power supply
I have a 2166 unit that starts up and runs until the the key is released to the run position. The problem is one of the 2 diodes that supply the fuel solenoid has broken. Over the years of use the insulation has failed and the diodes have come into contact with the cylinder head. I would like to replace the diodes instead of bypassing that circuit by adding a switch. I need some help in identifying the correct diode value or replacement part.
Old 05-18-2019, 02:27 PM
You can use: IN5400 Diode. Available at any Electronics Supplier or On-Line.
Roland Bedell
Buy: Made in the USA
