Greg Rozar AKA- CubDieselFan
Old 05-17-2019, 03:36 PM
go_aggies's Avatar
go_aggies go_aggies is offline
Default Mower deck
Hey guys I’m somewhat new to cub cadets and have a question about my 129. Can someone tell me if there is anything I can do to keep my mower deck cleared of debris? I mow a little over 2 acres of pasture with it and by the time I’m done the deck is packed solid with grass. The deck doesn’t have baffles in it anymore, but otherwise it’s in good working order. Just wondering if there is some kind of coating or paint that would help with the issue. Thanks for the help.
Go_aggies
Old 05-17-2019, 05:05 PM
mortten mortten is offline
How theyre build has a little to do with why they clog up. Bolt heads hanging down under the deck surface catch grease and the clumps keep getting bigger. Try to my when it’s dry. I scrape mine clean after each use. Helps keep them from rotting away also.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 05-20-2019, 09:59 AM
go_aggies's Avatar
Thanks Doug.
Old 05-20-2019, 11:02 AM
cooperino's Avatar
Install new baffles. Then clean and paint with some oil base paint...
Old 05-20-2019, 09:50 PM
athomas's Avatar
athomas athomas is offline
good advice, if grass is wet and high expect some clogs ! best thing to do is blow the clippings towards the previous mowed area to minimize the restriction of trying to discharge into unmowed grass if not already doing , get the front end up on some ramps and pressure wash the deck after mowing to remove accumulations and preserve the life of the deck, not much else can be done.
Old 05-21-2019, 07:45 AM
cooperino's Avatar
You bring up a good point in washing. The other day while at Tractor supply I saw this MTD Deck wash kit. I have seen these on newer tractors and wondered how well they might work on older style decks. Anyone try installing this on an older deck? Maybe install 2 "one on each side? I would assume you would run the blades with water connected and running.
Old 05-21-2019, 08:13 AM
athomas's Avatar
Never had/used one but I suspect it's one of those feel good devices, ( really doesn't do much but makes you feel good about using it ) ! lots of that kind of stuff around today. Hard to beat taking the deck off each fall scraping the crud off and pressure washing,sharpen the blades and paint the underside and it's ready for the next spring ! Crown makes a good cold galvanizing spray/paint I sometimes use.
Old 05-21-2019, 08:22 AM
cooperino's Avatar
I also sort of suspected the same thing, however I then thought. The way the "jet" is positioned it should remove some debris. If it were used after every cutting it might aid in during season cleanings.
For 30 bucks for 2 I might have to try them just as an experiment.
Old 05-21-2019, 08:42 AM
ejl6658 ejl6658 is offline
I have the OEM washing ports on two 54" 3000 series decks and they do not clean the deck very well at all. I think you would be disappointed with the results for $30.00 spent.
Old 05-21-2019, 09:11 AM
cooperino's Avatar
Thanks for letting me know. The idea seems good in theory. Maybe a good idea that could be improved upon somehow???
