Greg Rozar AKA- CubDieselFan
Old 12-23-2018, 10:03 AM
SS5150's Avatar
SS5150 SS5150 is offline
Default Tiller Gear Box
How is that tiller gearbox attached to that tractor? Wouldn't those both be aluminum rearend models? This from the 1711/1811 link Roland posted.
Looks like an aluminum housing to me.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 12-23-2018, 10:20 AM
The IH built tillers were designed for the Cast Iron Rear Ends S/N: <720,000
Above that serial range, a "adapting package" is needed.
Roland Bedell
Buy: Made in the USA
Old 12-23-2018, 11:27 AM
I had a 1711 with a cast rear end., It had a 3 point hitch like a 782.
Up to 530 and counting...
Old 01-20-2019, 12:27 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Originally Posted by SS5150 View Post
Attachment 97460
No, its cast, look at the axle tubes
1- 1200 in pieces
1- 1864 in pieces
Old 01-20-2019, 12:38 AM
SS5150's Avatar
What's the diff in the tubes?
I thought it looked like an aluminum rearend. It was advertised on a 1711 & 1811.
RUN IN THE RED
1872 project
Old 01-20-2019, 09:56 AM
Rescue11's Avatar
You know, i should back up, I cannot tell for 100% certain but I still believe it is a cast center like Lou said. Otherwise someone butchered that bracket to make it work.
1- 1200 in pieces
1- 1864 in pieces
Old 01-20-2019, 10:01 AM
Gompers Gompers is offline
Cast iron? Surely it must have been swapped. The 1711 is just the CCC version of the model year 85 782, quite a while after they had switched to cast aluminum sometime in 1983. Serial numbers are 737,625-747,224 according to all the docs I can find.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 01-30-2019, 02:18 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
I have a CCC 782 with cast iron rear was one of the changeover ones
Old 02-07-2019, 09:42 AM
SS5150's Avatar
I do as well, (a Y/W) but my serial # on it is under 720,000 (it's 706xxx if I remember right).
This pic was from an ad listing a 1711 & 1811, I just wondered how the gearbox was attached. Technically I think a 1711 would have been late enough that it should have been an aluminum diff is why I inquired.
RUN IN THE RED
1872 project
