Greg Rozar AKA- CubDieselFan
Old 03-02-2013, 12:06 AM
fourinchdragslicks fourinchdragslicks is offline
you could use a push pull cable to control the rear hydro then you would not have to worry about the independent axle movement pushing them out of sync. Use u or cv joints in the rear drive line to allow rear axle movement.
what size lift cylinder do you plan on using on the dump? You can calculate the lift capacity based on cylinder size (or the other way around). Knowing what your pivot and cylinder joint points are. IIRC the su15 hydro stalls around 600 psi
Old 03-03-2013, 03:11 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
had some time today to mount a tire to see how it looked on the 7x12 wheel.
Id like to have a wider rim but the tires look good on the rims.
Doug
Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772
Old 03-03-2013, 05:55 PM
The ags look good, Doug!
Proud owner of my Original!
Old 03-04-2013, 06:07 AM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Doug you going to load the tires?? If so man that thing will be HEAVY!! I really like the look of those tires.
Don Smith
Old 03-17-2013, 07:44 AM
4SPEED's Avatar
Im still working on it, just slow. Im gone all week and home on the weekend. so not much is getting done.
Doug
Old 06-09-2013, 12:10 AM
MADMachines MADMachines is offline
Any updates? What you have here so far is awesome, I can't wait to see the rest!!
PS- Is that a 2nd gen Firechicken I see on page 3? Mine's a black 78 and likely a lot rougher...
Proud owner of too much stuff!!
71, 102, 122, 123, 104, 127, 282 Hydro
(And that's just the Cubbies!)
I swear honey, just 1 more!!
Old 06-23-2013, 08:01 PM
4SPEED's Avatar
sorry no updates as of yet on the 1650. I had a few things to take care of before I start back on it. I will be taking out one axle, as the pump needs work and I dont want to put the money into it.
yes your seeing my 1979 1 0f 1530 built 4 speed trans am's. it'll be on desplay at the trans am nationals in Dayton OH , Aug 23,24,25th
I'll get back on the 1650 dump bed in the fall.
Doug
Old 06-27-2013, 12:15 AM
Very nice!! I'm a bit of a Pontiac die-hard, but I have some of everything these days...
Old 06-27-2013, 12:19 AM
I'll be looking forward to the results of the 1650 build this fall. Things always seem to get busier in the summer, at least around here! Unfortunately, I probably won't be able to make it to Dayton. I'm getting married the following week. I'm a little jealous of your toys! Keep up the good work!
