Greg Rozar AKA- CubDieselFan
Old 04-07-2016, 10:38 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Originally Posted by cyr2872 View Post
Good prices are the best prices. You'll love the EFI. I think the EFI setup I sent you mentioned it, but don't forget to wire in a MIL (malfunction indicator light) for trouble codes. My kit came with an LED which I install in an existing hole on the dash. Good luck!
My engine came with the MIL that I will install in the existing choke cable hole. I have the engine setting in the frame using a 1864 mounting plate and have the clamping diodes and a electric fuel pump so I should be able to start it up to check oil pressure etc. If it checks out ok I can notify the seller and then I will finish tearing the tractor down so I can paint the frame. I just wanted to be sure the engine is ok as it was a warranty job and he repaired it but never started it.
Later
Tom
