Greg Rozar AKA- CubDieselFan
Old 08-12-2018, 12:40 PM
Originally Posted by MiniXP View Post
Yes, figured it out pretty quickly when I looked again today. I had disconnected the wrong thing when I though I was disconnecting the brake rod. Disconnected the correct thing and it slid right apart.
I'm shocked.
Old 08-12-2018, 07:36 PM
This goes in the mail Monday
Old 08-12-2018, 07:44 PM
Billy-O's Avatar
Billy-O Billy-O is offline
You know my address....
Plow blade
#2 Cart
QA36 snowthower
Old 08-12-2018, 07:46 PM
I can make another one for you too
Old 08-12-2018, 07:54 PM
MiniXP MiniXP is offline
Thanks for getting it made so quickly.
Spent today getting it all cleaned up for when I have everything to put it back together. Wasn't planning on doing much, but ended up scrubbing and hosing the entire thing down, then doing some paint touch up. Need to go to my local dealer in the morning and pick up the correct colors, figured I'd get it primed with what I have though.
Old 08-12-2018, 08:05 PM
Alvy Alvy is online now
Mr. XP, good work so far. Looks like you have the original IH filter on it. Might want to change it and the fluid while you’re at it.
Jeff that coupler is sweet. I didn’t know you added the set screws on each side either. No wobble wobble now for sure.
Old 08-12-2018, 08:12 PM
Agreed, nice work on the 105
Just an added benefit of designing replacement parts myself. I make the collar a little longer and add set screws to keep these fine machines running.
Old 08-13-2018, 08:50 AM
Changing the fluid and filter is on the list as well.
I noticed one of my check valves appears to be stuck down. I pushed it down and it didn't pop back up. Is this normal? Will it pop back up once it is running or should it be popping back up now?
What do I need to do to it if it should be popping back up? Take it out and clean it, then replace the O-rings and washers per the service Manual?
Old 08-13-2018, 08:53 AM
cooperino's Avatar
That is normal.. It will pop back up when pressurized
Old 08-13-2018, 09:14 AM
It should pop up once the tractor starts.
Pap's 100
Restored 108
1211 Dual Stick
1050
