149 hydraulic lift issue
Good afternoon all I am new to this forum along with a new owner of a cub cadet 149. When I bought the machine over the summer I had to rebuild the engine. But when I got it the hydraulic lift would lift the plow that was on it. Since then I put a snowblower attachment on it and it will not lift it. I checked the fluid and had to put 2qts in it and still will not lift the snowblower. I adjusted the stop and still nothing. Any ideas on what the issue might be.
Thanks in advance |
First, welcome to OCC......
Does the tractor move forward/reverse normally...???
Yes moving the tractor forward and reverse works perfectly
I suggest posting a photo of the blower, hooked up so people can see that the linkage isn't a problem.
Other than that, it sounds like it just can't lift the weight. If so, the most obvious cause to me would be a worn lift cylinder allowing bypass. But I suppose the could be many other possible issues. Good luck! Andy |
Since the tractor moves OK, then it has to be in the "lift circuit". That would consist of the Control Valve, Cylinder, piping, and/or Control Lever linkages.
Change the hydraulic filter.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
I'm going to piggyback on this topic since it could be relevant. I have a 30" lift rod that works perfectly on my 1811 with my plow, but the rod is too long for my QA42 snow thrower. When the lift is all the way up and the plow is on the ground the rod just fits. Is there a shorter standard size rod? Should I fabricate one? I was thinking rebar and a torch.
Rusty 149 project with: QA42 snow thrower 38" deck Barn fresh 1811 with: 44c mowing deck QA42A snow thrower 42" snow blade |
Yes make one, it has to be shorter.
Don't use rebar. Go to Lowes or HD and buy a piece of 1/2 inch steel rod. Propane torch will work, Mapp gas better, OxyAcet best.
I'd suggest finding a local steel supplier. You can get metal stock for like 1/10th the cost of hardware store.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
Thread Tools | |
Display Modes | |
