CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 12-01-2018, 09:59 AM
RicochetFord RicochetFord is offline
Default Wide frame head light bezel question
On my 149 both screws that hold the head light retaining ring in are broken off. What are the chances that they could be drilled out and retapped for a bigger size? Any suggestions an repair? Also the ring is missing, anyone have any luck gabbing a new one? I removed the bezel from the hood last night and am not a fan of the big hole in the front!
File Type: jpg D06ABA4B-9DA4-44A8-BDCF-69DDB9EC01BA.jpg (28.5 KB, 195 views)
Old 12-05-2018, 12:51 AM
J-Rodz168's Avatar
J-Rodz168 J-Rodz168 is offline
Exactly the same issue happened on my 169, both screws were seized in the bezel from corrosion and snapped off. I drilled them out with a #21 sized bit, and retapped 10-32 threads. Then with a drop of blue medium strength loctite I screwed in a 2" long stainless steel threaded rod, and wing nuts. Good as new ever since. Before reassembly though I cleaned all the parts on a polishing wheel.
Old 12-05-2018, 05:12 AM
J-Rodz168
Good procedure and write up.
Roland Bedell
Buy: Made in the USA
Old 12-05-2018, 09:03 AM
J-Rodz168's Avatar
Smile
Thank you sir, glad to help.
Old 12-05-2018, 08:25 PM
Sorry that this is not related to your question that you asked, but man....what size tires are you running on the front of your cub? Seems like your steering would be quite limited, not to mention the surface area tension of the tires making it harder to steer.
Old 12-07-2018, 10:21 AM
I don’t remember what size they are off the top of my head but yes they are way to big. They were free and hold air, the ones on it when I drug this thing out of the weeds came apart as soon as I put air to them. So did the the rears.
If it had the deck on it steering would be impossible, your right. They just barely rub in the frame at full lock with out the deck. Temporary solution.
Old 12-07-2018, 10:23 AM
Thanks that answered the question perfectly. Now to just find a single headlight retaining ring for sale somewhere.
Old 12-07-2018, 10:50 PM
I think that someone in Ohio might make them and sell them EBAY. You might have a look and if so, then contact him and see if he will sell just one of them.
https://www.ebay.com/itm/CUB-CADET-HEADLIGHT-INNER-RETAINING-RINGS-100-149-86-127-122-124-70-71-72-73-129/273562232303?hash=item3fb19465ef:g:dhgAAOSwoHJbLr5 E:sc:USPSFirstClass!46224!US!-1:rk:1f:0
Thread Tools
Display Modes
