Greg Rozar AKA- CubDieselFan
Old 11-26-2018, 01:55 PM
hemimike hemimike is offline
Got a quote today for the entire hitch assembly shipped, about $470. Guess I got to figure out how much in parts it would be to fabricate the hitch and go from there. If possible, can someone give me the exact parts I would need from the website? Appreciate it.
Old 11-26-2018, 03:50 PM
You can look up the parts on the Cub parts site.
https://www.cubcadet.com/equipment/c...vice-and-parts
https://www.cubcadet.com/equipment/A...0-A/0035600001
Old 11-26-2018, 04:45 PM
I meant from extreme motor works. Few different options. Not sure which ones I would need.
Old 11-28-2018, 12:40 AM
I think I figured out what I would need. Can probably build it for $250-300, give or take a little. Just trying to figure out if I should hold out until I find one for sale or build my own.
These are the parts I think I would need:
3 point lift arms-cc-03-006
3 point lift link kit- cc-34-002
Adjustable 3rd link cc-35-002
Draft pins cc-36-003
Lift valve. ( from eBay)
Hoses (eBay)
Old 12-27-2018, 04:31 AM
I figured I'd post an update. Not a ton of progress but I think I at least have a plan. I picked up a parts machine, pictured below, so hopefully I will have everything I need for the hydraulics. I haven't decided whether I'm going to make or buy the lift arms, but I have a buddy that has some 1/2" x 3" bar stock I can have. Would have to but an inch off, bend, and weld in ball ends. I believe I have the materials to make everything else. Just got to do some measuring and then may be able to start making some of the components.
Old 12-27-2018, 11:26 AM
RLause's Avatar
RLause RLause is offline
When I made my lift arms, where I wanted the bends, I used the angle grinder to cut part way through the arm, made the bend in the vice and welded the crack shut. Worked out great with the bend right where I wanted it
Richard
Old 12-27-2018, 11:36 AM
Thanks for the tip. I got a turbo torch and mapp gas. Was going to try that but will notch it if need be.
