Greg Rozar AKA- CubDieselFan
Old 11-18-2018, 07:50 PM
Originally Posted by Lonstar View Post
My thought was to find a thin core that would fit in the area the battery is in. Not sure how yet, and have to add the thickness for a fan behind it. I'll keep this in mind though, thanks.
I like that idea as there is already a screen there.
Coops would be good too if you have room on the left side of the cab or mount it on the outside on the roof.
Up to 530 and counting...
Old 11-18-2018, 07:59 PM
cooperino's Avatar
The type of box i have would have to be inside the cab. Outside would cool to quickly. The air would be cold before it got to you. The core just doesn't have enough capacity. Also the ones i have are used on systems with 3 or more gallons of coolant. The kubota system might not have the capacity of coolant to keep the core happy. Welcome to try one tho.
Old 11-18-2018, 08:04 PM
Well then cut it in half and it will use less coolant.
You are like me, it is a Kawasaki not a 3 pin driver.
Old 11-19-2018, 10:23 PM
Lonstar Lonstar is offline
Originally Posted by TNTs CC View Post
That way I don't have to remove the heavy 6 window long version Sims cab anymore. That thing is heavy, I use my engine hoist to install it.
The picture I saw with the extended Sims cab must be yours! I was looking for it the other day but couldn't find it. It was a pic of the left side with the tractor in a garage. Is that yours?
I wish I had a longer cab. My high back seat hits the rear glass even with the seat all the way forward. Wanna trade?
Old 11-19-2018, 10:31 PM
The engine cooling fan draws air in across the battery threw the screen mounted under the dash. I doubt trying to blow air the other way will work real well. My plan was to mount one in the back corner of the cab.
This is exactly the type of info I was looking for. Thanks.
Don't have a 3205 so don't know how it's designed. Cart before the horse type situation? Do I get a 3205 without knowing if it'll work and make the best of it, or ask questions first....and then close my ears to what I don't want to hear and buy one anyway?
Back corner? So you're thinking of running coolant lines from front to rear? Isn't that too long for a cooling system / engine that small?
Old 11-19-2018, 10:52 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Surpluscenter.com has what your looking for. In expensive, compact. Exactly what you need
1- 1200 in pieces
1- 1864 in pieces
Old 11-20-2018, 01:37 AM
TNTs CC TNTs CC is offline
That's mine and no I won't trade. I'm too tall to run the seat forward. My seat just misses the glass when it's one click from being all the way back with my fat butt on it.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 11-20-2018, 01:41 AM
I'd look for a 3208 personally if I were you. I've seen a few JD's that use the same engine with a heater mounted there.
