60" Haban wheels
I have the early style Haban deck, it has 8" gauge wheels on the back & 6" wheels on casters on the front. I was wondering if there is a way to replace the steel bushings in the wheels. Mine are worn out & the cheapest I've found to replace the wheels is around $46 for the 8".
I had this info in my Haban file. these are from McMaster Carr. I have the front wheels on one of my Habans and so far they have worked well. The flanged sleeve bearings are for the casters.
Front Wheels Part #2938T55 SAE 863 Bronze Flanged-Sleeve Bearing, for 3/4" Shaft Diameter, 1" OD X 1-1/4" L X 1-1/4" Flange OD 4 each 2.98 $11.92 Part # 8368T57 High-Capacity Rubber-Tread Wheel, 6" X 2", 1/2" & 5/8" Axle, Roller Bearing, 820# Capacity 2 each $22.87 $45.74 Merchandise $57.66 Rear Wheels Dia wd shaft hub cap Cap price 8" 2" 1/2" 2 7/16" Spoked 450 2319T96 16.09 8" 2" 5/8" 2 7/16" Spoked 450 2319T95 16.09 8" 2" 1/2" 2 7/16" Spoked 1,000 8368T32 24.09 8"2" 5/8" 2 7/16" Spoked 1,000 8368T31 28.63 Bushings 1/2" ID 5/8" OD 1" long 1688K17 part # 1.64 ea
I recently rebushed the four wheels on my Haban with bronze bushings. Pretty straight forward and cheap, a couple $$ per bushing. If anyone really wants to know what size I used, I can probably find the receipt. I would suggest anyone going this route to knock the old bushings out and measure what they have to start with. BTW, a search will show lots of vendors.
Edit; Looks like Sam Mac already has provided dimensions.
122 original, well used. Owned since 1972 2182 new to me. Refurbished and gave to my son. Deere 4300 4WDA HST with FEL Many old Ford tractors, all gone now Couple old Ford trucks |
Hi,
Would you have the bushing size you used? |
Thanks for this info guys! I'm going to be redoing the wheels on 3 of my 60" Haban decks.
Thread Tools | |
Display Modes | |
