42" high vac deck and 1450
Looking at finding a 42" high vac deck from a 1440 to install on my 1450. Want to put the bagger back on said 1450, but it does not have enough power to run the 46" high vac deck properly. Anyone have experience with this?
I've never owned a 1450 however my 1211 has a GT46 and it seems to have plenty of power. I bag with it quite often even in high grass. I move at a decent pace. Not slow or fast but comfortable.
Did you change your pulleys at all? Kinda wondering if I have an engine issue then. It seems the deck does not have the "howl" like when i have the same deck on my 1864
I did not. I cant be sure the PO didn't tho. I can measure if you like. Just did wet leaves and grass today actually. I cant go super fast but i travel at a decent pace
if you wouldnt mind, just the drive pulley on the deck and pto pulley
Just a sec. I actually measured them once for some one here.. Let me look for the post.
Found it.. here is what I found when Alvy asked
Hey Alvy, Sorry for the delay.. Was dark this morning when I left for work. Ok. So outside diameters of pulleys. The PTO is 4.5" and the drive pulley on deck is 5.5" I use .5" wide belt on it. If memory serves its 101" My deck is a 336-190 deck if that helps
Thanks Coop!
Any progress with this Rescue11? I'm interested in this for my 1650....
