CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 07-14-2019, 03:05 PM
Rainman4820 Rainman4820 is offline
Ok I took off the brake pedal switch and it tested good (at least on continuity tester). I tested continuity from orange wire at seat plug to brake switch
which is good and then to dash light (brake pedal) and its good. I tested yellow wire from seat switch to ign switch and its good. I looked at the wire insulation for any obvious frays, etc...and it looks really good with no obvious breaks.
Any other thoughts on where to look?
Old 07-14-2019, 03:13 PM
why the engine dies when I release the brake?
Your testing did NOT check for shorts.
Take the Orange wire OFF the Seal Switch, insulate so it doesn't touch any thing, and see what you get.
Roland Bedell
Buy: Made in the USA
Old 07-14-2019, 03:21 PM
I took the plug with the orange yellow wire off the seat when I tested. Is that what you mean?
Old 07-14-2019, 03:29 PM
Yes, unplug the Orange wire, if it has that.
Roland Bedell
Old 09-23-2020, 10:13 AM
Tankman's Avatar
Tankman Tankman is offline
Might it be possible to just use an on/off switch for the PTO? On or Off?
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 09-26-2020, 05:05 AM
Tankman's Avatar
Default 1641 Seat Switch
There could be a number of issues that will give you the same condition.
Considering, you replaced the Reverse Relay not that long ago, the next culprit I would suggest is the Seat Switch (Black one). That switch has to close (when you sit on the seat), to keep the Relay energized. Check that out with a VOM or DVM. Check & advise.
Where is the seat switch located? I don't see one on my 1641.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 09-26-2020, 06:15 AM
The switchs are located under the part with the springs.
Old 09-27-2020, 09:05 AM
Tankman's Avatar
Thanks Sam! You've always been right on!
Tankman
'95 CCC 1641
Eastern PA
USMC
Thread Tools
Display Modes
