1641 Carb Issues
Turned the key and no clicking in the carb and I realize now that the solenoid is stuck. The mower has been sitting a while but I use non ethanol fuel and it doesn't look too bad.
I drained/replaced all of the fuel, cleaned the float, needles and everything I can get at. Any advice on getting the solenoid to engage? edit: I just noticed a similar post and will plan to let it soak in carb cleaer and I have ordered a 807723. Any other thoughts on what I may do in the interim are appreciated. |
Do you have 12 volts going to it when you turn the key on?
My 1641 did the same thing a couple years ago. I pulled the fuel shut off solenoid out and cut the plunger off. Haven't had an issue with it since. I didn't have the time to get another solenoid because of a snowstorm and being my only snow removal machine I had no other choice. Never bothered getting another one because I have seen no difference in the operation of it.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
What Kelly said. Or you can get fancy and buy the OEM plug that Briggs sells.
Yes I was getting voltage to the solenoid and I have ordered the plug you mentioned. Many thanks
