I had a similar problem on my 782D but only after the wife would mow the lawn. While operating the hydraulic lift, she inadvertently also moved the second lever that operates the front outlets. While that in itself wasn't the problem, the problem was that the other lever wasn't used often, so when it was moved with the lift lever, it was stiff and did not recenter when released. When I saw the levers were not re-centered in the same position, I moved them to be at the same centered position and the lift began to work properly. I worked the other lever several times and lubed the linkages with no more problems.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
Thread Tools | |
Display Modes | |
