Greg Rozar AKA- CubDieselFan
Old 05-26-2019, 12:49 PM
Hope you get your 1512 running again Allen, some things you can't do without!
Up to 530 and counting...
Old 05-27-2019, 05:37 PM
Thanks Lew!
The new alternator and regulator came today! Anyone want to come help install them?
Proud owner of my Original!
Old 05-27-2019, 10:06 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
When the alternator seized up on my 782D I did not get a new one, but simply replaced the bearings in it. It has been running fine for years. If I recall, There where 2 ball bearings used a number KB-15531-74180, (may be superseded by another number) but was only about $ 12.00 each.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 05-28-2019, 11:57 PM
Thanks Frank. Hopefully, after the new alternator is installed, the 1512 will be good for a long time.
Old 05-29-2019, 11:23 AM
looks like that bearing might be a sealed both sides 6201, but not sure.
IIRR the Harley panhead 6v generators of the 50's used that common little bearing but it's been 50+ years since I rebuilt one.
I'd suggest not to pitch that alt. if all it needs is a pair of bearings.:beerchu
Old 05-29-2019, 07:23 PM
Will be keeping it, George. Will have it rebuilt, and put on the shelf.
Old 05-29-2019, 09:49 PM
FrankF3's Avatar
Yes George, both sides of the bearing is sealed.
Old 06-01-2019, 05:22 PM
Update on the 1512. The water pump is seized. Going to get a new one ordered.
Old 06-01-2019, 07:58 PM
twoton twoton is offline
.....The water pump is seized......
Ouch!!!
Old 06-02-2019, 06:55 AM
You may as well plan on replacing the belt while your in this far. The joys of owning a diesel.
