Greg Rozar AKA- CubDieselFan
Old 06-16-2019, 11:14 AM
cooperino's Avatar
Sam is right! I would flush the whole system before doing anything.. I like to use diesel with a small electric fuel pump I keep around for stuff like this.
Old 06-16-2019, 12:56 PM
This filter is rated up to 1000 PSI I don't know what the pressure is on the return side. I doubt that you would need something this robust but here is the info.
https://www.donaldson.com/en-us/engi...emblies/hmk03/
This filter is rated for 200 PSI and it looks like it would do the job.
https://www.surpluscenter.com/Hydrau...ter-9-7291.axd
Hope someone can let us know what the return line pressure is.
Old 06-16-2019, 02:40 PM
IH1086 IH1086 is offline
I took the filter housing off my log splitter and rigged it up to a cheapo water pump from Harbor Freight. I ran diesel fuel through it. My only concern is that the pressure wasn't high enough to clean everything out? I had to help the ram move, but cycled it 4 times. I ran hytran in it after but it hardly pushed that at all. I took the filter off and just let it dump into a pail. That helped. If there's a little diesel in there yet I don't think that will hurt? There wasn't anything in filter that I could see. Maybe I'll cut it open? I have a rebuild kit for the hyd valve coming, so I'll see what's in there when I get it apart. If I find anything at all in there, the rams and steering are coming apart!
Old 06-17-2019, 03:38 PM
Here is a high pressure filter at Surplus Center
https://www.surpluscenter.com/Hydrau...ter-9-7293.axd
Old 06-18-2019, 03:00 PM
Sam, I smell what you're steppin in!
I guess I'll see what I find inside it, and go from there. I'd have to do a little replumbing to find a spot to mount it too? It's pretty big.
Old 06-18-2019, 03:33 PM
Yep you would probably need to remote mount it and have some hoses made up.
