Greg Rozar AKA- CubDieselFan
Old 05-12-2019, 10:08 AM
Mainemann77 Mainemann77 is offline
Default Changing blades on a 3 blade deck
Hi, newbie here. Most likely a silly question, however, how do I go about changing the blades on my belted 3 blade deck? Deck is currently removed. Also, should I get new OEM blades or sharpen the old ones? Old ones look pretty good but do I need to be concerned about balancing? Thanks in advance!
Old 05-12-2019, 11:15 AM
dale c. dale c. is offline
use a impact wrench , if they look good sharpen them equal amount on both ends
Old 05-12-2019, 11:21 AM
Hello and first, . Next, with the deck removed, use a wooden block to hold the blades in place (just need to hold the blade that you are removing in place if your belt for the spindle pulleys is removed). Then, using an air ratchet, unbolt the blade from the spindle assembly while noting the direction and side of the blade (use a sharpie if needed). Sharpen your blade and balance it. Then you can replace it and move on to the next one, until all 3 are sharpened and balanced. No need to replace blades if they are still good.
As far as if they need balanced, the answer is YES. If you don't balance them and they are rotating at a high rate of speed, then that will cause unnecessary stress on your spindles and all of their components, which will eventually lead to bigger problems then just balancing your blades.
Old 05-12-2019, 12:03 PM
https://www.homedepot.com/p/Maxpower...3006/301952278
