CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 01-23-2019, 08:42 AM
Seanc's Avatar
Seanc Seanc is offline
Default 129 hydraulic lift /trans swap
I am converting my 129 to hydraulic lift. I found a killer deal on a transmission from a 127 with a ported hydro pump for $100 . I already purchased it, and am picking up this weekend. Now I’m wondering if it will fit right onto my 129? I was hoping to service it and just swap transmissions insteAd of taking the pump off. Also I got the ram, hydro lines and control valve. Looking for whatever mountaing brackets and hardware I need as well as the rear lift. Any direction is helpful. I hope I made a good purchase
Old 01-23-2019, 01:25 PM
dodge trucker dodge trucker is offline
Looking to do the same thing to my 129, only my donor is a 1650.
Old 01-23-2019, 01:53 PM
I believe I have changed over all of my Wide Frame Hydro's to hydraulic lift, it's a fun and useful project.
Personally I prefer to only change the pump, doing this affords you the opportunity to replace the cork gasket helping to insure a leak free install.
You will want to look carefully at the "new" pump, 127's NEVER came from the factory with a ported pump. (that's not to say that someone didn't put a ported pump into a 127 sometime in the past 40 years).
The next question is, what did they use the ports for? That could be a whole different kettle of fish.
Good luck with your change-over.
Old 01-23-2019, 08:07 PM
Great to see you posting again Yosemite Sam! He's has done a great job converting his WF's over to hydraulic lifts. I recommend you check out his pictures in his profile sometime and see how he even did it with a NF external pump. Crafty lil' ornery varmint he is....
I swapped a 1650 rear into a 129 and everything went nice and smooth. Your transition should go well for you
Old 01-23-2019, 09:10 PM
wagonmaster wagonmaster is offline
Can a non ported pump be ported?
Old 01-24-2019, 05:45 AM
The short answer is .....NO
Roland Bedell
Buy: Made in the USA
Thread Tools
Display Modes
