CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 01-18-2019, 04:08 PM
Cambria cub Cambria cub is offline
Default Hydraulic lines
Was wondering what the length of the hydraulic hoses are from hydraulic spool valve to front quick connectors on a 1811/1812.
Old 01-18-2019, 05:41 PM
Sorry put in wrong section
Old 01-18-2019, 08:41 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Measure the distance from your spool to the outlet hole. They are just hoses.
1- 1200 in pieces
1- 1864 in pieces
Old 01-18-2019, 10:02 PM
If no one has the length, Mock up a route with with a coat hanger or baling wire.
Then you have something to measure.
Seems like on my dual spool 782, they don't run straight, they curve and lay on the motor mounting plate, but it has been a while since I've been in there.
Old 01-27-2019, 12:49 PM
yeeter yeeter is offline
I dont know the length, but yes they come out of the valve and down then sideways across the motor plate then up the inside right side of the frame. I do not believe they are both the same length.
Pretty sure I have some pics somewhere in my threads, since I did both a 782 and an 1811 with front hydraulics. But never measured.
Found some pics in this old thread:
https://www.onlycubcadets.net/forum/...t=38210&page=5
Old 01-27-2019, 02:47 PM
DieselDoctor's Avatar
I just installed a pair on the 1572 restoration I'm doing which is the same nose as your tractor. Both hoses are the same length and part #.
Thread Tools
Display Modes
