Greg Rozar AKA- CubDieselFan
Old 07-15-2011, 10:30 AM
Ron Howe Ron Howe is offline
Exclamation electrical short
I have a 1999 model 2165 16 horse Briggs & Stratton. I can't seem to find the short. It blows the fuse that has a red wire to the ignition switch and a red wire to the battery. I have replaced the ignition switch and the starter. Could it be the solenoid?
Old 07-15-2011, 10:37 AM
Originally Posted by Ron Howe View Post
I have a 1999 model 2165 16 horse briggs & stratton. I cant sem to find the short. It blows the fuse that has a red wire to the ignition switch and a red wire to the battery. I have replaced the ignition switch and the starter. Could it be the solenoid?
Ron I moved your thread so you can get help with your problem.
Old 07-16-2011, 08:08 AM
When is it blowing the fuse? That wire feeds power to everything when the tractor is running or is it when you are cranking it?
Old 07-16-2011, 11:25 AM
as soon as i turn the key
Old 07-16-2011, 11:55 AM
Sounds like a short in the wire some place touching the chassis. Have you checked the wire runs yet?
Old 07-16-2011, 06:48 PM
dfreed's Avatar
dfreed dfreed is offline
I have a 2186 that was blowing a fuse during the start as I was passing the position on the switch for the lights. One of the wires had a bare spot that was grounding on metal. It took me a little bit of wire tracking to find it, but it solved the problem.
Dierik
Old 07-18-2011, 09:12 AM
[QUOTE=dfreed;82980]I have a 2186 that was blowing a fuse during the start as I was passing the position on the switch for the lights. One of the wires had a bare spot that was grounding on metal. It took me a little bit of wire tracking to find it, but it solved the problem.
I traced the wiring diagram and found nothing shorting out on the frame. I did run a screwdriver across the soloenid and it cranked over and started. Could that be it?
Thanks for all the help.
Thread Tools
Display Modes
