Greg Rozar AKA- CubDieselFan
Old 05-20-2019, 09:46 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Default Digital timing light to check RPM?
Can you use a digital timing light with a tach to check the RPM on a K Series? If so, how?
Old 05-21-2019, 10:05 PM
Does anyone know?
Old 05-22-2019, 07:07 AM
I would assume that depends on the Manufacturer of the Digital Tach. I have seen some that check 8 - 6 - 4 cylinder engines only. You have to find ones that only do 1 cylinder engines.
Roland Bedell
Buy: Made in the USA
Old 05-22-2019, 08:18 AM
mickb72 mickb72 is offline
I have used my old dwell meter set on 4 cyl. Take the reading 1k x 4 = 4000rpm. I use a couple Tiny Tacs also. Mike
Old 05-22-2019, 08:19 AM
ironman's Avatar
ironman ironman is offline
The inductive pickup of the light clamps around only one spark plug wire, (the number one plug wire) and reads rpm from each time that plug fires. If you clamp it around the plug wire of your one lung Kohler, it won't know that it's not a Boss 429 Mustang.
Here's a manual..... https://csr.innova.com/Content/Manua...82582054484284
Old 05-22-2019, 09:55 PM
Thanks for the replies!
Thread Tools
Display Modes
