CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 06-25-2014, 06:47 PM
mike deitriech mike deitriech is offline
Default How do you restore plastic panels on a 1641?
I have a 1641 an the hood an side panels are pretty faded, I was wondering if anyone has tryed to restore them. Should I just paint them an if so what was there original color? It looks like a cream color now but I wasn't sure if they used to be white. Im not going for a full restoration I just want to clean it up some this winter. Thanks for any info.
Old 06-28-2014, 08:48 PM
generally once plastic starts to lose its color theres no going back, if the color is ok but dull you can try buffing it. the best bet to make it look new is to paint it but make sure the paint is flexible enough for plastic and use an adhesion promoter so it doesnt peel. to paint plastic you want to scuff it with a gray scuff pad real good and wash it with hot soapy water, once it drys wipe it down with degreaser and spray on the adhesion promoter followed by the paint.
Old 06-28-2014, 10:40 PM
cc_bob cc_bob is offline
You might try a little rubbing compound in a test area to see if it's just oxidation.
If you paint..
When prepping for paint on anything it's always a good idea to wash it and use wax/grease remover BEFORE you start sanding. Reason being if there's any wax or oils you can embed them in the scratches making it difficult to remove. That is until the solvents in the paint hit it...
BTW, this is not an opinion, just about all brands state this in their p sheets and labels. For example, CLICK. (note the first bullet point).
As Olds455 mentioned there are flex additives for paint as well as adhesion promoters you can use.
Good luck!
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 06-28-2014, 11:40 PM
Thanks for the replys guys. Im gonna go ahead an paint them this fall. Do any of you guys know if they are supposed to be white or a off white color? I have looked up many pictures of other 1641's an still can't figure out what they are supposed to be. Some look lighter than others.
Old 06-29-2014, 05:52 AM
The plastic is a creamy white.
Old 06-29-2014, 09:52 AM
Great, thanks
Old 08-12-2014, 11:09 AM
rdehli rdehli is offline
on my 1864 I used a little rubbing compound and a lot of elbow grease.
Old 08-12-2014, 12:40 PM
Rather than restore faded plastic panels, I simply re-cycle them!!
It is better for the environment and my stress level!!
Thread Tools
Display Modes
